water in oil tank
Old Feb 24, 2010 | 06:58 PM
sir nose's Avatar
sir nose
Default water in oil tank
why would my mates zetec have water in the oil breather catch tank?
its not coolant.i guess it must be moisture,about 1/4ltr in 24hrs.
Old Feb 24, 2010 | 07:34 PM
That's a serious amount of moisture, or is he doing short local trips not really getting hot ?
tabetha.
ps was the rail ok with the adaptor ?
Old Feb 25, 2010 | 05:37 PM
sir nose's Avatar
sir nose
yes the rail is pukka ive had to move the strutbrace and i ordered the wrong size hose cos' i measured the underbody pipe which isnt the same as the rail.oh well.cheers for sorting out the rail.
Old Feb 25, 2010 | 07:19 PM
No probs matey, it's no problem, I'm machining some fittings for the oil pressure switch area for extra sensors ie pressure, temp, warning light switch.
markeh
Ford Focus Diesel
Apr 11, 2016 02:15 PM
155lee
Oct 27, 2015 04:55 AM
IainRS1700T
Sep 25, 2015 06:44 AM
Brickhouse
Sep 21, 2015 11:00 AM
Chopshop85
Sep 18, 2015 06:13 AM
