bought myself G220 Polisher, what pads do i use with what?
Old Feb 24, 2010 | 11:37 AM
Twellsie's Avatar
Twellsie
Default bought myself G220 Polisher, what pads do i use with what?
it came with some white, yellow and orange pads, what do I use with what products, is there any tutorials anywere?
Old Feb 24, 2010 | 11:59 AM
xr4x4rs's Avatar
xr4x4rs
what car you using it on, 60 or 80 grit pads will work a treat on the bmw
Old Feb 24, 2010 | 12:07 PM
JK99's Avatar
JK99
Try the Polished Bliss website for guides etc. They're a helpful bunch.
JK
Old Feb 24, 2010 | 01:09 PM
Gav Diamond's Avatar
Gav Diamond
http://www.detailingworld.co.uk/foru...apolishing.pdf
Have a read of this mate, just make sure you have quite a bit of spare time, lol
Will tell you all you need to know.
Old Feb 24, 2010 | 05:35 PM
Twellsie's Avatar
Twellsie
Cheers guys
Rich, I will pop round with the angle grinder to give the escort a polish, once its painted
Old Feb 24, 2010 | 06:03 PM
xr4x4rs's Avatar
xr4x4rs
aslong as i can turn the german barge into a convertable
Old Feb 24, 2010 | 07:05 PM
Twellsie's Avatar
Twellsie
concentrate on finishing your escort, before embarking on other projects
Old Feb 24, 2010 | 07:19 PM
xr4x4rs's Avatar
xr4x4rs
its getting done, its going for paint next week
Old Feb 24, 2010 | 09:04 PM
Moonstone Mo's Avatar
Moonstone Mo
i like menz pads,which i think are the ones you may have,and the sonus sfx
Old Feb 25, 2010 | 07:25 PM
vaughant's Avatar
vaughant
The white and orange should be the harder ones generally used for compounding rather than polishing,where compounding meaning removing dust and runs after 1500 from fresh paint or heavy oxidisation in old paintwork.I find faracela g3 saves pretty much anything heavy but be VERY CAREFUL as even with water it's easy to burn through.I like to wet flat 1500 or 2000 (use a "block" for any runs/dust)first and then compound on low speed with plenty of water til you achive a basic sheen then speed it up a bit to get mirror finish.swap the head then for the softest one you have in the kit,douse it in water and turn speed up again and basically buff all the excess g3 off the car to give you a stunning finish.a nice tip if your not sure if you've gone far enough is to put the polish on,buff it and then use some panelwipe to wipe off the excess and this will then show you what it would look like when finished.practice makes perfect so keep the speeds low at first and plenty of water and you'll be ok.
Old Feb 25, 2010 | 07:29 PM
vaughant's Avatar
vaughant
Also forgot,always keep the mop moving and watch all the edges etc as you can easily burn through there!!!
Old Feb 25, 2010 | 08:18 PM
vaughant's Avatar
vaughant
Just read the PDF description and some top info there,worth reading HOWEVER,it dosent work exactly that way in the real world as when they say it's hard to burn through or "strike through" believe me as someone who does this on a regular basis weekly it's very EASY to burn through.leave it on a patch for more than a few seconds and that's generally it.although I mainly work on fresh paint,it's really easy to do so keep it wet and you'll be a lot safer.I tend to keep an old 2 litre water bottle full with a hole made in the top of the lid to squeeze onto the metalwork when your using it.you'll soon get used to it and the machine you've bought looks the dogs to be fair.good luck ! !!!
Old Feb 25, 2010 | 08:42 PM
Twellsie's Avatar
Twellsie
Vaughant, are you saying you need to keep it wet when polishing? as I didnt notice that as i read the PDF
Old Feb 28, 2010 | 05:42 PM
vaughant's Avatar
vaughant
Talking
[QUOTE=Twellsie;4750362]Vaughant, are you saying you need to keep it wet when polishing? as I didnt notice that as i read the PDF[/QUOTE
hi mate,yeah,it does mention it late on in the PDF but I would say if you've not done much with this before you can burn through very easily.it does depend on the cutting compound u use but I use faracela g3 which is a harsh compound and therefore you need to be very confident to use without water
,certainly something I wouldn't do and I've done this for a long time now.there is a g3 that is more like a liquid in a tube which apparently you don't require water on but I've used it a bit and wasn't too impressed with the finish.I believe they sell a very similar product in halfords in a yellow tube but I haven't tried it.out of interest,what are u using it for?
Old Mar 1, 2010 | 03:41 PM
Twellsie's Avatar
Twellsie
this is the stuff I have got, do i need to use it with water or not?
Old Mar 3, 2010 | 07:45 AM
vaughant's Avatar
vaughant
Sorry mate,what compound are you using,should have a code of some description on it,g3,g11 etc.I think there's a comparison in the PDF but if you know post it up and I'll find out at my suppliers for you.it won't harm to use water on any of them really but as a guide g3 in a tub is almost like a heavy paste,is that what urs is like?
Old Mar 3, 2010 | 08:16 AM
Twellsie's Avatar
Twellsie
lol, i s'pose the link to what i am talking about would help http://www.polishedbliss.co.uk/acata...MasterZG220HP0
Steve Escos
Ford Focus ST Parts for Sale
Sep 2, 2019 11:39 PM
yatta
May 21, 2016 10:31 PM
155lee
Oct 27, 2015 04:55 AM
IainRS1700T
Sep 25, 2015 06:44 AM
3dr cossie
Alloy wheels and ICE for sale
Sep 2, 2015 08:58 PM
