Aftermarket ECU on N/A?!
Old Feb 23, 2010 | 09:08 PM
hineho87's Avatar
hineho87
Default Aftermarket ECU on N/A?!
Hi,
After speaking to a few people and companies, it seem that the std ecu on the focus (iv got a 1.8 mk1) is quite hard to map and if it is there is limited gains.
People have suggested a custom map or piggyback ecu, and these seem be around £400/500. Do these give any gains?
If not is it worth upgrading to aftermarket ECU, so the fueling and cam timing etc can be fully adjusted? I no these are norm around £900/£1k supplied/fitted/mapped.
Again wot gains wud be got and is it worth it on a n/a car (with exhaust/induction/cams etc) that isnt TC/SC/ITB's?
Or is the price that makes it not worth it?
Matt
Old Feb 23, 2010 | 11:37 PM
pdfbt40's Avatar
pdfbt40
The EEC-V PCM is quite sophisticated but its not difficult to MAP. What's difficult is accessing it as it uses a Ford/Visteon propriety protocol. Quite a few people have cracked it but keep the necessary information to themselves. The only firm who distribute an access software is DreamScience Flash.
The Ford MAP is pretty well optimised, but mainly for emissions, with good safety margins for reliability. It can be tweaked, but you won't see much more than 5% increase in torque on a N/A.
I run a 2.0l engine with ported induction, stage 3 head and cams, ST170 exhaust. The PCM has a Bluefin MAP giving about 150lbft torque. I recon there might be another 5% using a custom MAP or alternative ECU, but I don't think its worth the cost involved.
Martin
Old Feb 25, 2010 | 01:37 PM
As said bhp versus cost is a no no.
Old Feb 25, 2010 | 01:40 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Different engine, but this is my Clio before and after we fitted an Mtech V4 and mapped it, I would certainly recomend this ECU to others, although your gains may not match mine obviously:
SO much scope for further improvements in the future then too, in my case I fitted throttle bodies a couple of days later and found another 15bhp or so straight away
Old Feb 25, 2010 | 04:11 PM
hineho87's Avatar
hineho87
will check that out when i get home as cant view pics at work. Herd gud things bout the V4 ecu by Mtech.In that case i prob wont bother unless i decide to go dwn TB/SC/ITB route.Will not bother with remap as herd you get minimal gains and dont spending £300+ for few bhp.Matt
Old Feb 25, 2010 | 04:17 PM
jammerrs's Avatar
jammerrs
if you plan to take the enigine further then go for it but otherwise i wouldnt bother
Old Feb 25, 2010 | 04:27 PM
hineho87's Avatar
hineho87
see thats the thing im unsure wot to do yet. As prob other routes i will need to upgrade the kent cams iv got so will prob keep for another yr then buy car with high bhp as std (Focus RS/ST ).Matt
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
griffo69
Oct 4, 2015 11:58 AM
