s reg van 55 weight
Old Feb 23, 2010 | 07:47 PM
daz1977's Avatar
daz1977
Default s reg van 55 weight
hi guys, i am not sure weather this is the right place, but i have a question regarding van weight
i have an s reg 1.8 d 55 van, inside the van there is a sticker thats says weight 550 kg inlcuding driver passenger and load, does this include a full tank of fuel or not ie is 550 kg plus fuel or 550 kg inc fuel
cheers for your help
Old Feb 23, 2010 | 07:51 PM
Escow-Van's Avatar
Escow-Van
I had always assumed the 550kg was for the load in the rear, I thought manufacturers stated the weight of vehicles with all the fluids in...
Old Feb 23, 2010 | 07:57 PM
daz1977's Avatar
daz1977
i am not sure, i am window cleaner and this topic has brought up a few different answers on a forum, so am trying to get a answer
Old Feb 23, 2010 | 08:01 PM
Deerhunter's Avatar
Deerhunter
formerly uyo1972
the specs for a van of this year
kerb weight 975-1010kg
max gross vehicle weight 575-1800 kg
exact kerb weight depends on modle .refere to vin plate
info taken from a haynes
Old Feb 23, 2010 | 09:03 PM
Northants Ford Fan's Avatar
Northants Ford Fan
550kg does not include fuel, driver or any other bits in the van its the total carrying weight, quite a few people get into trouble with vans over this as the assume for example that a 190 transit means it can carry 1.9 tonne load when the weight of the driver and fuel and any other bits in the van need to be deducted from the 1.9 tonnes
Old Feb 23, 2010 | 09:28 PM
daz1977's Avatar
daz1977
so to clarify i can carry a load of 550 kg + full tank of fuel and a driver
Old Feb 24, 2010 | 01:15 PM
MrMPuk's Avatar
MrMPuk
No, the 550kgs needs to include the tank of fuel and people.
So your load capacity can be quite small if you have a full tank of fuel and 2 large people up front. This will also include silly things like ply lining which I know doesn't weigh a lot but it all adds up.
wowk
Mar 30, 2021 07:49 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Neil Clark
21
Oct 1, 2015 07:02 PM
AJC
Oct 1, 2015 06:47 PM
