Master cylinders
Old Feb 22, 2010 | 08:48 PM
JoshXR2's Avatar
JoshXR2
Default Master cylinders
Is it common for master cylinders to just suddenly stop providing a decent amount of force to stop said car.
Just I changed my brakes today worked before then new calipers on nasty air leak when bleeding said calipers now when engine on pedal to the floor no brakes.
Would i be right in thinking the master cylinder is goosed?
Old Feb 22, 2010 | 08:58 PM
studabear's Avatar
studabear
sounds like there could be air in the system
Old Feb 22, 2010 | 09:23 PM
JoshXR2's Avatar
JoshXR2
there is an air leak somewhere. Traced it to where the master cylinder bolts to the servo
Old Feb 22, 2010 | 09:27 PM
Matthew_M's Avatar
Matthew_M
is there a rubber seal in between the master cylinder and the servo?
i had an air leak there but it was due to corrosion on the servo itself
Old Feb 23, 2010 | 06:07 AM
JoshXR2's Avatar
JoshXR2
Ah well there is no rubber seal there and the servo is rusty. I think brake fluid has been leaking out cos there is lots of surface rust
Old Feb 23, 2010 | 02:21 PM
tejy's Avatar
tejy
if u've taken the calipers off completely then ur gonna needta bleed ur brakes all the way round..if ur still having problems afta bleeding the brakes then u'll defo need a new servo
and no theres no seal between the cylinder and servo
i upgraded my brakes when i tried 2 bleed the brakes it wasnt happening so hadta change the cylinder..cost me about 40quid new from euro car parts..
Old Feb 27, 2010 | 05:14 PM
JoshXR2's Avatar
JoshXR2
have changed the master cylinder today bled, rebled the rebled the brakes again still the car only just stops. gonna try another servo tomorrow.
could it be the calipers i've changed too? they are wilwood superlight 4pots
Nov 1, 2015 06:53 PM
muzzman1
Sep 30, 2015 08:59 PM
