Bailey oil breather fitting??? rwd saph.
Old Feb 22, 2010 | 03:23 PM
fluxysaph's Avatar
fluxysaph
Default Bailey oil breather fitting??? rwd saph.
I'm about to fit a Bailey oil breather system to my saph. Bailey istructions say to put a return to the exhaust side of block via a supplied adaptor, but I have been told to ignor this and return that pipe to the sump. I have a blanked off adaptor already fitted to the sump.
Which way of fitting is best please?
Old Feb 22, 2010 | 06:06 PM
Sump, must be below oil level or it just acts as another breather, bailey talk out thier arse.
Old Feb 22, 2010 | 08:40 PM
ECOS95's Avatar
ECOS95
If its a 3 port:
1 large pipe at the top of the breather goes to the location of the original breather (which you remove) under the inlet man.
The other large pipe goes to the other side of the block under the turbo. You need the adaptor that Bailey supply.
The small outlet at the bottom of the breather goes to the sump below oil level.
Old Feb 24, 2010 | 11:30 AM
fluxysaph's Avatar
fluxysaph
Cheers guys.
RUBY123
Oct 22, 2023 12:04 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
JoeyBoyden
Aug 18, 2015 10:52 PM
gingerturbo
Aug 18, 2015 07:58 PM
155lee
Aug 14, 2015 11:21 AM
