removing scratches from glass
Guest
Posts: n/a
hi everyone im looking for a good product to remove some light "pollishing machine caused"scratches from an area on my side window of my rst. are there any such products out there or any tips you guys use.the swirls are about 1cm wide by about 8 inches along the top of the window.ive lived with it for ages but now id like to at least make them less visible without replacing the glass
thanks
Cheers Dave
thanks
Cheers Dave
hey dude i work with glass and personally id just go down the breakers and see if they have any.
if u try and polish it out it will leave a blemish (dip) inthe glass which is as annoing.
or maybe t-cut its worth a try!
hopes this helps.
hopes this helps.
Orion_Gav
Sep 29, 2015 04:50 PM
