rewiring fuel pump, s2 rst
Old Feb 19, 2010 | 03:30 PM
RSandy's Avatar
RSandy
Default rewiring fuel pump, s2 rst
wiring to my fuel pump is questionable upon inspection, so would feel much better rewiring it, better safe than sorry
need a bit of help, a guide, a wiring diagram, as i have no idea exactly what im doing lol. i believe i am in need of a 4 way relay? run fresh live from battery to pump, fresh earth, and use existing live from existing relay as a switch feed? basically im unclear, and any help would be great
cheers
Old Feb 20, 2010 | 02:46 PM
You need a boggo std SPST, single pole single throw switching relay, these are the yellow ones ford uses and will have 85 86 87 and 30, or 30/51 markings.
Personally on the S1 S2 I would just also get a fuel pump cut off from a scrap mondy/escort etc, then wire direct from position 2 of the ignition switch to the relay switched supply(86), 30 is battery input through a fuse, 85 is earth, and 87 is the output from the relay to the pump, through a fuel cut off for safety.
Run your earth direct to the battery.
There are loads of threads on this under cossie fuel pump rewire, don't worry if the relay has both 87 and 87a, this just shows it to be a change over relay, will still work as before, depending on whether supplied(switched on) or not will determine which terminal the supply come outs of, 87 when un switched 87a when switched.
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 27, 2015 04:55 AM
15
Oct 7, 2015 03:43 PM
tib2220
Sep 14, 2015 12:33 PM
Billy_RS
Sep 13, 2015 04:17 PM
