Do these coilovers adjust on the rear?
Old Feb 19, 2010 | 09:15 AM
shaz1990's Avatar
shaz1990
Default Do these coilovers adjust on the rear?
Right received my coilovers, i know how the fronts adjust, now do the backs adjust or are they fixed (see pic)??? It says they adjust, there is a plate that sits under the rear springs, inside this plate is another plate that adjusts, spin it and it twist up or down (adjusting) then you can tighten it with 3 alen key nuts but cannot understand how this can compress the spring??? Can anyone help?
Old Feb 19, 2010 | 11:26 AM
Sp3no's Avatar
Sp3no
Yes the rear is adjustable, As you spin the plate it compresses the spring against the weight of the car effectivly shorteneing the spring
Old Feb 19, 2010 | 01:36 PM
shaz1990's Avatar
shaz1990
Sorted it! Its funny to try and picture how it works off the car, thanks anyway!
jessie_rs
62
Aug 6, 2019 09:27 PM
yatta
May 21, 2016 10:31 PM
S3an
Sep 26, 2015 11:39 PM
S3an
13
Sep 13, 2015 10:01 AM
