RS will not fire when hot
Old Feb 17, 2010 | 08:21 PM
djchurch2001's Avatar
djchurch2001
Default RS will not fire when hot
My rs turbo has real issues starting when engine has some temperature. The car will fire first time when stone cold but as soon as it has some running temp it takes a while to fire. Its not the starter motor as this is easily turning the engine. I find the best way to get the car to fire is to have the accelerator pushed to the floor then turn the car over this normally works. Could this be a sensor or poor fuel pressure?
Old Feb 18, 2010 | 10:44 AM
Check your CO, and for any air leaks, then check the igntion timing.
Old Feb 18, 2010 | 12:41 PM
djchurch2001
is this the CO sensor that could be on its way out?
DixieTheKid
11
Jun 6, 2020 11:20 AM
PeterLucas
Sep 21, 2015 11:36 AM
BRAMMER
15
Sep 14, 2015 08:52 PM
