Escort RS1600i This forum is for all things about the Escort RS1600i
RS1600i gearbox ???
Old Feb 17, 2010 | 07:24 PM
Sideways Si's Avatar
Sideways Si
Default RS1600i gearbox ???
i've got a gearbox i believe is from a RS1600i so it should have a lower 5th gear, can someone tell me where the ID numbers are and what they should be??
Thanks in advance
Old Feb 17, 2010 | 08:01 PM
XR2's Avatar
XR2
There's a small metal flag on the gearbox. In most cases it's missing nowadays.
RSi had three or four different ratios for 5th gear, most came with shorter 5th than XR3.
RSi gearboxes are the only ones with CPS hole on the bottom of it...
Old Feb 17, 2010 | 08:14 PM
Sideways Si
cheeRS
wot's the cps hole???
Old Feb 17, 2010 | 08:19 PM
XR2's Avatar
XR2
Crank Position Sensor
Later CVHs had it bolted into the bottom end and markings on the back side of the flyheel, RS1600i was the first CVH with distributorless ignition, the CPS was bolted onto the lower side of the gearbox, the CPS used the starter teeth on the flywheel...
Old Feb 17, 2010 | 08:28 PM
Sideways Si
cheeRS mate
Old Oct 20, 2017 | 06:46 AM
Desy52's Avatar
Desy52
Thank you very much helped, for a long time I was looking for the answer to this question.telltractorsupply
mjonathan24
Oct 29, 2015 10:39 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
Iain Mac
Sep 30, 2015 09:39 PM
Benleys
Escort Range
Sep 28, 2015 01:56 PM
