CVH Pistons question
Old Feb 17, 2010 | 12:33 PM
ultra's Avatar
ultra
Default CVH Pistons question
Hi, I started rebuild my '86 1.6 CVH engine, and change lean burn head to the older '84 hemi head. Now I can't choose the right pistons for my engine
Some catalogues have the same pistons for the pre '86 and post '86 engines, at MAHLE catalogue I found three types of piston for 1.6 CVH. Can anybody help me? Whitch pistons I need to use?
Old Feb 17, 2010 | 04:46 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
you want pre 86 pistons.
i'm guessin non turbo?
if so non turbo ones.
Old Feb 17, 2010 | 07:51 PM
JesseT's Avatar
JesseT
All the NA 1.6 pistons pre -86 are the same, carb or injection. Post -86 injection models also use the older type "hemi" piston. This pistons have the raised crown on both sides of the pistons.
The post -86 carburettor engines use the lean burn head and tehy only have the raised crown on one side of the piston.
The third type of 1.6 CVH piston is the low compression turbo piston.
Old Feb 17, 2010 | 08:13 PM
ultra's Avatar
ultra
Thanks!
The engine is non turbo.
If I understand correctly -
this is post '86 piston
and this is pre '86
So at the catalogue I foud two types of pre '86 pistons:
In-line engine, fuel,
CVH, LRB, EFI
1597 cmі,
77/84 kW (105/115 PS)
9,5:1
injection,
Vehicle:
Escort RS, Escort XR 3i
Orion, Fiesta XR 2i
link to catalogue description - http://www.motorenteile.mahle.com/eL...#spa1398887107
CVH
1598 cmі,
66 kW (90 PS)
8,5:1
injection,
catalyser,
Vehicle:
Escort XR 3i, Orion
ink to catalogue description - http://www.motorenteile.mahle.com/eL...#spa1398887021
They have the same dimensions, but different compression ratios and catalogue numbers... I'm confused...
Which one I need to install?
Old Feb 17, 2010 | 09:45 PM
MAHLE's Avatar
MAHLE
MAHLE UK
Hi ultra,
our catalogue only shows the basic dimensions, hence the pistons appear identical. However, the piston crowns are slightly different designs albeit difficult to tell even if you compare the two pistons side by side. I have an advantage of the the original cad drawings to refer to...
You want the 9.5:compression ratio piston, from memory this is 013 38 xx (xx denotes piston size).
Regards,
MAHLE UK
Old Feb 17, 2010 | 09:48 PM
liam-rst's Avatar
liam-rst
shit happens
i have a brand new set of 3i pistons im not usin ill check part numbers 4 u
Old Feb 18, 2010 | 05:29 AM
JesseT's Avatar
JesseT
#2 is totally the wrong piston and has not been used in any cvh pre 86. This is the piston used in the rarer 90ps, KE-jetronic injected, catalytic converter, "eco" model, Escort.
Old Feb 18, 2010 | 07:10 AM
ultra's Avatar
ultra
Thank you!
mk3ste
Oct 17, 2021 10:09 AM
Nov 1, 2015 06:53 PM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
deathrider666
Sep 28, 2015 06:12 PM
