Ford Sierra & Escort Cosworth Uprated Differential Mounts.
PassionFords Creator
1x Uprated Poly Rear Differential Mount To Suit All Ford Sierras and also the Escort Cosworth
(These are genuine uprated units from USA, not cheap welded up rubbish)
This is a brand new laser-cut, CNC-machined, TIG-welded, anodised, and compression molded aluminum & polyurethane differential mount!
This differential mount fits the following vehicles:
- All Ford Sierras (XR4i, XR4x4, RS Cosworth, RS500, including Sapphires)
- Merkur XR4Ti
- Escort Cosworth
Along with the rear beam mount bushings, the differential mount is the most important bushing to upgrade on the car. Unfortunately, it is also the most overlooked bushing to replace. A weak differential mount causes a whole slew of issues that aren't necessarily transparent to the driver. First of all, the ride height of the car sags as the mount ages.
Basically, the chassis, which pushes down on the differential mount, ends up sitting closer to the differential case and the beam since the differential mount lacks compressive strength.
Additionally, the weak rubber of the mount allows the subframe to move around, which causes the rear end of the car to feel squishy and slow to respond. This problem isn't limited to merely ruining the experience for the driver though. A subframe that moves with respect to the chassis creates significant toe changes that tremendously decrease handling grip and straight line grip. On an mc²racing car, which is a particularly punishing environment, you can actually see the rear wheels move back and forth in the wheel well with your naked eye while the car is accelerating when a factory differential mount is installed.
Besides the loss of grip and loss of driver confidence, the motion of the subframe also allows the rear tires to contact the wheel wells in hard corners when wider-than-stock wheels are fitted.
By the way, ALL originally-installed differential mounts are weak regardless of mileage! It is our opinion that even brand new Ford differential mounts are too weak to use on any vehicle that isn't being restored for showing at a Concours d'Elegance.
In the past, we were able to purchase Group N differential mounts for exorbitant amounts of money to solve the problem of the weak differential mount. Sadly, the manufacturing of the Group N diff mount has ceased, and those mounts are no longer available. Fortunately, this beautiful mount duplicates the performance of the Group N part, but it greatly improves upon the execution.
To begin, this mount is lighter than the Group N part despite it's beefy construction. Furthermore, and this is really exciting, the polyurethane bushings are easily replaced. When a Ford differential mount goes bad, you throw it away and purchase a whole new mount for large amounts of cash. When the polyurethane in this differential mount goes bad, you pop in new bushings at about 1/6th the cost of a new Ford mount.
This mount will greatly improve the feel and responsiveness of the rear end of your car, increasing both lateral and straight-line grip, and will certainly be one of the sweetest looking parts you will ever purchase for your car. With the polyurethane isolating the chassis from the differential, you won't have to worry about feeling any vibes, either. This mount is suitable for all applications from daily drivers to race cars.
This Item far exceeds all its competition that we have seen and tested.
Beware of cheaper items that create a lot of noise in the car and in some cases even align the beam slightly too low due to bad design, thus causing more problems than it cures!
Be carefull out there!
Price: £120 Inc vat.
Click here to go to our webshop & purchase. / call us on 01253 508400 / e-Mail us on sales@remapping.co.ukThe astute amongst you may notice these are available slightly cheaper from the USA, but please bear in mind that I only charge more because I do of course have to pay the import duty and shipping costs myself to get them here, as would you have to and then we need to add UK VAT. These are usually in stock, and always shipped to you from Blackpool in the UK.
Please Note:
We have had two Escort owners report the mount bolts rubbing on the roll bar very slightly and had to file the bolt heads down a little. We have not personally experienced this but feel its worth mentioning here just in case.
definately on my wish list. After reading all the info above i'm pretty convinced it could be the cure to the floaty feeling the back of the car has had.
With all due respect, I have fitted at least 20 of these personally, in house, and they certainly dont foul. I would be inclined measure yours and see if you have had an ARB upgrade fitted to yours.
But where in the item description does it state these are only compatible with standard ARB's ?
I have one fitted to my sapph and also had the "slim"(grind) the head of the top bolt down a bit dur to arb contact but it was well worth the little bit of hassle
Please dont let the above put you off its by far the best way to get your rear ride hight sorted
As above aswell.
Everyone I know who has fitted one to an Escos has had to use different bolts due to fouling the standard arb, just as myself when I fitted mine.
But none the less, a very good bit of kit and a worthwhile purchase once the bolt arrangement has been catered for.
Jack and the Beanstalk
Aug 15, 2015 04:27 PM
