Technical essay Archives A collection of topics you really shouldnt have missed first time round if your interested in the technical aspect of how these Fords work..!! Also many Workshop manuals available in downloadable format. Access is available to Gold Members only.
head bolt setting
Old Feb 14, 2010 | 09:28 PM
chriscossie's Avatar
chriscossie
Talking head bolt setting
hello people can same one help with the head bolt setting for a sierra cosworth 2wd i am puting on a group A HEAD GASKET so i need the toque settings.
thanks chris.
Old Feb 14, 2010 | 10:02 PM
coswurv's Avatar
coswurv
Torque settings for standard ford headbolts, i use arp lube under the bolt head to washer surface and some on the threads,
45ftlb
90deg turn
90deg turn
Old Feb 14, 2010 | 10:12 PM
chriscossie
hello mate are they the full settings for that gasket .
Old Feb 14, 2010 | 10:17 PM
coswurv's Avatar
coswurv
yes mate i got these setting a while back from nms and i have used them on several engines with the YB1261 GASKET AND THE YB0611 which is what you have i think, they have all been fine, my car runs a bigger turbo with grey injectors plus 32psi of spike boost and has held together!!
Old Feb 14, 2010 | 10:20 PM
chriscossie
45ftlb
90deg turn
90deg turn
witch order do they go in on the head
Old Feb 14, 2010 | 10:25 PM
coswurv's Avatar
coswurv
Basically start in the centre and work your way out staggering up and down the head but in all honesty do a search on here and im sure you'll find a pic, the bolts have to be all done up in stages as i posted above not all 3 stages on each bolt at once.
Old Feb 14, 2010 | 10:30 PM
chriscossie
hi mate where do i look to get picture pls
Old Feb 14, 2010 | 10:43 PM
chriscossie
hello mate i found these sequences do they sound ok top 9 3 1 5 7 bottom 8 6 2 4 10 of a head that i have found tighten to 50 nm then to 180 degrees.
Old Feb 14, 2010 | 10:50 PM
coswurv's Avatar
coswurv
Here is a pic ive just found, i use the settings i gave you, they came from one of the best tuners about and have worked on my cars so use them if you want if not use some others,
Old Feb 14, 2010 | 11:09 PM
chriscossie
Thumbs up
hello mate thanks for the pic the settings you have sent my do i do 45ftlb first then do i do 90deg turn after i am only asking because it is my first time at it.
thanks chris.
Old Feb 15, 2010 | 05:29 AM
coswurv's Avatar
coswurv
Yes go along and do the bolts up with a ratchet just pinch them up, then go along and follow the setting again doing each bolt to 45ftlb, then follow the settings again turning each bolt a rotation of 90 degrees then follow again with a further 90 degrees, but also remember to use some lube.
Old Feb 15, 2010 | 05:19 PM
chriscossie
Talking
hello mate thank you for all your help i am going round to fix the car no wish me luck.
chris.
Old Feb 15, 2010 | 08:47 PM
coswurv's Avatar
coswurv
chris.
Just take your time mate, any things you dont understand just ask on here im sure myself or others can help.
Old Feb 15, 2010 | 10:42 PM
chriscossie
Talking
hello mate can you tell me what the degrees is on the distrubitur cap as the timeing is slightly out because it wont run under its own steam can you help me again please.
chris
Old Feb 16, 2010 | 08:45 AM
coswurv's Avatar
coswurv
chris
I take it the rest of the engine is timed up correct?, the arrows on the cam pulleys face each other, exhaust at 3 o'clock and inlet at 9 o'clock or there abouts, then the little lug on the crank pulley (just left of the grooves on the pulley) needs to be inline with the little tab on the face plate, if you've done this then one of the other lugs on the pulley will be dirctly inline with the crank sensor at the bottom of the engine. Take the dizzy cap off when the engine is at tdc and pull the rotar arm off, you will see that on the edge lip of the distributor itself there is a tiny line cut into the lip and at tdc the rotar arm has to be inline with this groove so place the arm back on and twist the dizzy until there inline and then do the bolt up to hold the dizzy in place, that should be it.
Old Feb 16, 2010 | 10:41 PM
chriscossie
Thumbs up
hello mate thank you for all your help just one more question the car runs ok but it runs a bit slow may be you might no
chris
FlashRS
Aug 30, 2015 08:07 PM
Steve Escos
Aug 24, 2015 07:56 AM
saul1988
Wheels and Tyres
Aug 24, 2015 06:42 AM
track.focus'd
Aug 12, 2015 05:53 PM
Zoggon
Aug 10, 2015 10:39 AM
