custom rs turbo ecu chip ?
Old Feb 14, 2010 | 06:03 PM
muttsnutts89's Avatar
muttsnutts89
Default custom rs turbo ecu chip ?
i have two rs turbo chips....one has a power enginering skicker on it i opended up and found a blue s marked on the chip...done some research and found it could be a superchip. Now the other one i opened up and removed a metal tag...i had been told it was chipped as wel not so sure tho. it has got a small white sticker on it and i think it reads rst 88 s2 AB 16/7/02 i think....done a bit more research and found there could be two types of chip... boost removal one and a (AB) custom one ??? if it is chipped is it ok to use as i am unsure of boost level and ign map ect.... any advise would be great. tried to upload pics but cant figure out how to...if it helps i wil try to upload some. regards ryan
Old Feb 14, 2010 | 07:02 PM
bobbi96's Avatar
bobbi96
hiya mate, the chip with the S on sounds like a superchips chip, and the other one sounds like a ahmed bayjoo chip not 100% sure, sum pics would help, i dont know your engine spec so best advise would be to get it set up by someone who knows what theyre doin before you end up damaging something,
Old Feb 14, 2010 | 08:19 PM
muttsnutts89
http://photobucket.com/ryan_091
Old Feb 14, 2010 | 09:06 PM
muttsnutts89
i think it is not s2 infact L2 would that make it a level 2 chip, stab in the dark ?? lol and the ab is has a circle around it, as you can see from the pics. regards ryan
Old Feb 15, 2010 | 08:35 PM
muttsnutts89
any one got any ideas ?? thanks.
Old Feb 15, 2010 | 08:39 PM
Mark Shead's Avatar
Mark Shead
It is a Ahmed chip it may have a boost limit in it, If you speak to Grove garage they should be able to tell you what the spec is,
This is by far the best chip.
Mark
Old Feb 15, 2010 | 09:20 PM
muttsnutts89
Mark
cheers ill give them a ring.
big_Rad
Sep 15, 2017 09:36 AM
manuel boeckx
13
Oct 3, 2015 02:29 PM
Matt Baxter
Sep 16, 2015 08:30 PM
JasonPD
21
Aug 20, 2015 07:36 PM
Bailes1992
Aug 16, 2015 07:14 PM
