cylinder head
Old Feb 14, 2010 | 04:16 PM
H.RST's Avatar
H.RST
Default cylinder head
hi,
im in the middle of rebuilding a friends cvh cylinder head, after his cam belt snapped. i have changed the valves, and lapped them in, and have put it all back together, lifters, rocker arms etc. But, this is the question, when i put the cam to the timing mark, number 2 exhaust valve is open by about 3mm. is this normall on a cvh head, or could there be other problems, like the cam for instance??
cheers harry
Old Feb 14, 2010 | 09:26 PM
forevaford's Avatar
forevaford
sounds normal to me, 1 3 4 2, 2 is on exhaust stroke (ex valve open)
Old Feb 14, 2010 | 09:30 PM
liam-rst's Avatar
liam-rst
shit happens
yh sounds rite to me m8, as long at timin marks are sopt on it should be fine
Old Feb 17, 2010 | 02:09 PM
essexRSTSouthend's Avatar
essexRSTSouthend
Yup thats fine mate.First time i did it i thought the same.best of luck with the rest of it.
Old Feb 17, 2010 | 03:27 PM
As said don't worry about the valves in anu cylinder other than the one you're doing, ie no1.
BTW, if the valves have been cut on a serdi seat cutter no need to lap in, they seriously are that accurate with seat cutting.
Nov 1, 2015 06:53 PM
