cylinder head rebuild
Old Feb 14, 2010 | 02:53 PM
H.RST's Avatar
H.RST
Default cylinder head rebuild
hi,
im in the middle of rebuilding a friends cylinder head, after his cam belt snapped. i have changed the valves, and lapped them in, and have put it all back together, lifters, rocker arms etc. But, this is the question, when i put the cam to the timing mark, number 2 exhaust valve is open by about 3mm. is this normall on a cvh head, or could there be other problems, like the cam for instance??
cheers harry
Old Feb 14, 2010 | 02:58 PM
H.RST's Avatar
H.RST
it is a 1.6 turbo cvh head!
Old Feb 14, 2010 | 04:37 PM
Rob_DOHC's Avatar
Rob_DOHC
are pistons 2 and 3 up when the crank is on its timing mark? if so this sound okay.
Rob,
Old Feb 14, 2010 | 05:08 PM
H.RST's Avatar
H.RST
Rob,
yer 2 and 3 are down?
Old Feb 14, 2010 | 05:27 PM
project rs's Avatar
project rs
thats right when crank is at tdc then 1 and 4 should be at uppermost of travel and the cam sounds right too
Indyrs
Dec 4, 2022 12:39 PM
muzzman1
Sep 30, 2015 08:59 PM
IainRS1700T
Sep 25, 2015 06:44 AM
coscor86
Sep 20, 2015 01:21 PM
