has anyone bought one of these new cossie idle control valves?
im in need of a new one just wondered if there any good?
http://cgi.ebay.co.uk/Ford-Escort-Si...item20ae7e7191
cheers
cheers
It says he's sold 6, what I have done in the past is to look at the feedback, then contact previous buyers to see if the thing works, you also get a bit of a longer term report this way as well, rather than I've had it one day and it works!!
u still not get urs to work after cleaning it?! did mine last week, took it apart and cleaned it up etc but it still sticks at 1500-2k revs when u touch the throttle after starting it doh!!
Mine has a mind of it's own, so just disconnected it, going to make a alloy bung to go in place and run without one as it idles when stone cold anyway, needs just a few secs holding then ok, they seem to be a pain, but most are 20+ years old so did good service!!
yea mines the same, tis fine when its unplugged, probably takes a few mins of holding it then its ok to drive, althou still need to sort the hesitation as that isnt helping!!
