idle speed control valve problems
Old Feb 11, 2010 | 05:34 PM
alanwddll's Avatar
alanwddll
alanwddll
Default idle speed control valve problems
as above having problems when i plug the sensor into the idle speed control valve the revs shoot straight up to about 2000 but when i unplug it again they go back down to about 700 to 800 wich is a lot better but the engine struggles a little.
i have taken it off and cleaned it but no different
any ideas
cheeRS alan
Old Feb 11, 2010 | 07:30 PM
martysmartie's Avatar
martysmartie
Either the valve is jammed open or it is being told to open this much. Check to see if valve is shut when disconnected, engine should not struggle other than when you start from cold you will need to compensate for ISCV with throttle.
Martin
Old Feb 11, 2010 | 07:53 PM
The fact that the speed alters at all shows the valve not to be jammed.
Something is telling it to open that much, start with basics like testing CTS output.
Old Feb 11, 2010 | 08:25 PM
martysmartie
Sorry misread question, to the second point I said must be being told to open this much.
Martin
muffster
13
Sep 3, 2015 09:40 PM
Sheepdisease
Aug 30, 2015 09:11 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
Zoggon
Aug 10, 2015 10:39 AM
