do dump valves
Old Jan 6, 2005 | 10:31 PM
escort-cossie-owner's Avatar
escort-cossie-owner
Default do dump valves
loose you boost
Old Jan 6, 2005 | 10:32 PM
mattbibs's Avatar
mattbibs
not one that is working correctly!
Old Jan 6, 2005 | 10:33 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
lose you boost if they leaking, and they can do
Old Jan 6, 2005 | 10:39 PM
essexrsturbo's Avatar
essexrsturbo
they severly lose you boost!
when you come of the throttle!
Old Jan 7, 2005 | 11:58 AM
Jim Galbally's Avatar
Jim Galbally
on part throttle they can loose you boost if the spring isn't strong enough, as the pressure differential will cause the diaphragm to lift and all your lovely boost to be released into the engine bay.
this won't be an issue on full throttle
Ginge !'s Avatar
Ginge !
just finding my feet
jim get back to work !!!!!
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
RS-Rikki
Sep 21, 2015 07:27 AM
rs_jim
Sep 19, 2015 08:41 PM
