15 inch
hi
i hav a 15 inch wheel but it will not fit, the center hub is to small on the rim for my car. and the holes dnt line up, is there anythin i can do or can i change the hubs bt dnt knw which 1's will wrk. its a escort mk3 plz help
Get the wheels you have re-drilled?
I have BBS rMs on mine that were designed for audi 80's,the centres had to be drilled out from 57mm to 63.4mm,depending on the wheels design you can have the current PCD holes welded and then redrilled?
What wheels are they?
Johnny Knoxville
Sep 30, 2015 07:21 AM
DavidK
Sep 27, 2015 02:55 PM
ossie cossie
Sep 21, 2015 05:07 PM
