Should i repalce this camshaft?
Old Feb 9, 2010 | 09:46 AM
stafcio's Avatar
stafcio
Default Should i repalce this camshaft?
hello everyone.
look at this camshaft, should i replace it? it is worn but not extremely.
Old Feb 9, 2010 | 09:51 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
if it's worn replace it.
have you mesured the lift on the lobes and compared them with each other?
if not, get a caliper out and measure them, if it's only the tiniest amount of variance you should be ok, but approaching 0.1mm is quite bad and will make some cylinders run leaner/richer than others.
Old Feb 9, 2010 | 10:33 AM
stafcio's Avatar
stafcio
no i haven't measure them. will do.
thanks for the advice!
Old Feb 9, 2010 | 03:44 PM
Karlos G's Avatar
Karlos G
Balls Deep!
lmao!! If you can see any wear then bin it!! The lifters will be worn also and so you'll be well down on power.
Make sure you change them together and run them in properly to have any chance of survival.
Old Feb 9, 2010 | 03:47 PM
crazycage's Avatar
crazycage
looks like there is no lobe left on the left hand side first pic,that will be number four cylinder i bet.
Old Feb 9, 2010 | 04:04 PM
rstdave's Avatar
rstdave
As above, to me it looks pretty well worn tbh, i've binned cams that looked no worse than that!
jessie_rs
62
Aug 6, 2019 09:27 PM
Nov 1, 2015 06:53 PM
Marino
Sep 12, 2015 11:10 AM
foreigneRS
Technical essay Archives
Jul 20, 2004 11:29 AM
foreigneRS
Jul 20, 2004 11:06 AM
