Escort Van running problem
Old Feb 8, 2010 | 11:18 PM
sikora's Avatar
sikora
Default Escort Van running problem
I have a 1999 Escort Van 1.8 diesel (non turbo) which has been playing up. Basically it stutters a bit when driving. I can compare it a bit to when i HT lead is on its way out on a petrol engine. Something holds it back for a second, then it goes again. Other times it still drives ok but feels a little underpowered. This is alot more noticable when cold but doesn't completely disappear once warm
I've changed the fuel filter and injector crossover pipes, as well as running injector cleaner through it.
Old Feb 9, 2010 | 09:23 AM
Did you use MILLERS injector cleaner, this is awsome stuff and the best I've found.
What make of filter did you use ?, delphi are well worth paying extra for, it may be you are starting to suck air from a perishing filter head diaphragm, see if it is nice and solid the pumpy bit.
Old Feb 11, 2010 | 06:47 PM
sikora's Avatar
sikora
No wasn't Millers injector cleaner. Fuel filter was a Fram item. I'll check the button on top of the filter housing but i'm pretty sure it gets solid
Any other suggestions?
Old Feb 11, 2010 | 07:55 PM
Seriously, try some MILLERS, have known it make big differences on cars already treated with other makes first.
Old Feb 12, 2010 | 02:43 PM
cosworth726's Avatar
cosworth726
had same problem with 18 fiesta turned out to be the copper washers under the injectors run great after
Old Feb 22, 2010 | 07:52 AM
sikora's Avatar
sikora
Still having problems with this. Wouldn't even start this morning. Starter motor turns and it'll fire for a second if i press the accelerator, but then cuts out
Fuel primer is solid and fuel flows from the pipe that goes to the injector pump.
This is twice now that it wont start. Both after only starting the van up to move it. Seems to start ok the day after a longish drive.
druidgetafix
Aug 15, 2015 10:22 AM
S3an
Aug 11, 2015 07:26 PM
Zoggon
Aug 10, 2015 10:39 AM
gjh
Aug 5, 2015 04:21 PM
