formula ford gearbox?
anyone kno where i could find a gearbox from a formula ford? me an a mate was thinkin bout which way to go with his project an iirc the formula fords used to use a 2.0 pinto engine so this box would be great for wot we have in mind
formula fords use the 7/11 crossflow mate, same bellhousing bolt pattern as the pinto though so i'm assuming you could get a clutch to mate the two if needed
edit: only just realised this doesnt help with your question but i'd keep an eye on ebay, proberbly your best bet
in theory then it should bolt up to a YB then? with a gearbox, i just looked it up an historic formula fords used a 1600 an 2.0 pinto so should be able to use a formula ford clutch too
the hewland they use is actually based on a vw beetle gearbox. Plenty for sale usually on www.racecarsdirect.com - called a mk9
edited to say if would be to weak if your planning big hp, in which case you need an fgb with a ford adapter, bu that going to be 5k plus secondhand
a mate of mine deals in this type of cars and parts he will have what ever you need drop me a PM and i will see what he has for you
cheers bud were just tryin to work out a rough cost of major components atm, not that my pal is shy of a few quid lol but he def wants a mid engined xr2, its just which way to do it. bhp wise it wont be a high output thats y we were thinkin pinto with this box,
unless youre going to hang the rear suspension off the casing like in a formula ford, I see no point in using a horrifically expensive casing wrapped around an inverted beetle cluster. Personally Id be getting an audi 1.8 turbo engine and transaxle and fitting that. Same basic box layout, 5 speeds, strong, reasonable power, modern engine that doesnt eat valvegear and then design your own suspension like Andy gallaghers multilink of a kitcar style frame made of box with double wishbones tied into the cage.
Like I say, the hewland box is just a beetle box in a clever case with all the suspension mounts etc inbuilt. If youre not using any of that, its a LOT of money for a transaxle box. Youd be better off using a renault or audi one with an adaptor for the ford flange IMO (theyre 50 quid instead of a couple of grand)
Maybe get on to www.touringcarspares.com although its not a touring car part your after, he may have contacts that can help.
van_dogg_pavvy
Mar 3, 2016 09:30 AM
borboyous
Aug 22, 2015 11:17 AM
