Reversing Light
Mines not working at the moment.
We have checked the bulb. Its OK
We checked the holder which is the same as the fog light holder. Its OK
The holder is getting the voltage so it must be an earth fault.
does anyone know where it will be earthed?
had anyone else had this issue?
Thanks
Thanks
Thanks
Thanks
I worked on a ST-2 recently with the same problem. I changed the bulb holder and it fixed it.. Yours may be the same issue?
Regards
RS-STspares.co.uk
The fog holder looks, exactly the same.
cheers
I'm pretty sure these are switched earth anyway, so you will always have +12v. Check to see if you have continuity between the earth pin and the chassis when reverse is selected.
deathrider666
Sep 28, 2015 06:12 PM
The Enigma
Sep 12, 2015 10:12 PM
