EFi wont run after 15mins
Old Feb 7, 2010 | 03:19 PM
terribletaj's Avatar
terribletaj
Default EFi wont run after 15mins
Hi,
Got a small problem, I have a series 1 RST with OFAB EFi, if I start the car from cold it runs fine, a little lumpy on idle but nothing to serious, once it's warmed up and driven for awhile, if I switch it off and wait around 15mins then switch it back on, it runs very lumpy, and wont rev properley, massively over fuels, chucks loads of black smoke on idle. Almost like the timing has been retarded loads
If I leave it for 45mins till its cold again, it starts and runs fine. I have changed the injector loom, injectors, leads, plugs, map sensor, TPS, CPS, idle mixture adjuster, IAT sensor, cleaned out the ISCV, reset the ecu, but still the same problem.
Anyone had anything like this?
Thanks
Old Feb 7, 2010 | 03:23 PM
Matthew_M's Avatar
Matthew_M
have u tried disconnecting the cold start valve?
Old Feb 7, 2010 | 03:27 PM
terribletaj
I didn't think the EFi system has a cold start valve, if i unplug the ISCV, then it wont even idle.
Old Feb 7, 2010 | 03:32 PM
Matthew_M's Avatar
Matthew_M
sorry my mistake didnt read the thread properly
Old Feb 7, 2010 | 04:41 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Coolant temp sensor maybe, it thinks the engine is still cold so gives too much fuel
Old Feb 7, 2010 | 04:42 PM
studabear's Avatar
studabear
to be honest I would be changing the coolant temp sensor next the ecu 1
Old Feb 7, 2010 | 04:56 PM
terribletaj
ok will give that a try, seen a cossie management conversion for sale, so might just get that instead of messing about with this system anymore
thanks
Old Feb 7, 2010 | 05:08 PM
studabear's Avatar
studabear
I'm starting to convert mine 2moz, I was at jano oddkidds yesterday, I now have 90% of my parts, another trip to msd i will have 95% so Its spanners out time
dombanks
Sep 21, 2015 08:38 PM
RSmark84
Sep 13, 2015 01:29 PM
Eigdoog
Sep 13, 2015 05:46 AM
dms04
Sep 11, 2015 01:57 PM
bigryrs
Sep 7, 2015 06:45 PM
