Aero Catches - hard to close?
Old Feb 6, 2010 | 05:14 PM
S1's Avatar
S1
Default Aero Catches - hard to close?
Ever since I fitted my Aero catches on the bonnet one was always a bitch to clsoe but I put it down to the pin being slightly out of line. Today I took them off to fit another bonnet and found even with it not fitted it still was a bitch to close. One is sort of ok but the other one needs a proper wallop to close. I looked at the mechanism and found if you pull the pin forward it works ok, it looks like its going over-centre so jams up. They've had hardly any use so its not wear and tear. Any one else having problems?
Old Feb 6, 2010 | 05:40 PM
RichieST's Avatar
RichieST
A friend of mine has them, took a while to get them lined up and working properly as there's not much margin for error!
Old Feb 6, 2010 | 05:44 PM
Tev's Avatar
Tev
Wd40
I have them i my bumnper, I took he bumper off to do some work n left it out itn the rain with the catchs open
The went soild, quick squirt of wd n they are like new again
Old Feb 6, 2010 | 06:07 PM
e30cossie's Avatar
e30cossie
E36 cosworth
I had a set like this and one was faulty like you described. I ended up getting another set.
Old Feb 6, 2010 | 06:17 PM
Steve the Plumber's Avatar
Steve the Plumber
The original Rouge Trader
Ive got them on my bonnet and front bumper, they need a drop of WD40 now and again.
sridgett
Oct 1, 2015 07:30 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
The Youth.
Sep 30, 2015 09:59 PM
SMILER258
Sep 28, 2015 09:04 AM
