ooops
this is wot happens at 100mph in 4th combined with single valve springs!!
b4 anyone slates me sayin i should have known better with the springs the prev owner lied an said they were done, should av checked i kno
You do not need double valve springs to do 100 in 4th on a cvh
Yours must have been seriously weakened to do that. When you say evidence is clear, how so? Was it definitly valve bounce or is it possible the valve head has dropped off?
edit: not trying to argue, just clarify
i would say bounce but its not impossible for the head to av dropped off, but ass the stem was slightly bent i imagine the head must av come into contact with the piston while still attached to the stem although its poss it could have made contact with it from travellin on the piston, i knew nothin of the engine b4 i got it could av been original springs 4 all i kno, the bloke i got it off also said it had a full arp kit on it which was also bollox
not a prob anyway ill have the new engine in soon 2 maybe 3 weeks, good excuse for more power without the missus moanin, all she knows is im fixin it lol
tbh as soon as i see the oil cap had blown off i knew it was pretty terminal lol an if i wasnt so impressed with the damage i would av cried instead of laugh lol, there were bits of piston in unimaginable places, even a bit forced up the side of a lifter, the turbo blades were covered in molten alloy an every pot was scored
u live an learn tho lol
you mean the bent stem of the valve, after the cylinder got lean so ran super hot after detting and theheat found a weak point in the valve head for it to fall off and smahs you pistons up
id imagine the bent stem wasbecuase of whats left of the vale head being thrown around in the chamber and your engine revving still at high rpm lol
but it is shit when it happens as its happened twice on me on my old rs turbos
when you get a new engine go efi
, dunno how to resize my image lol.
It is a possibility i was just assumin valve bounce tbh with the bent stem an all that but thinkin bout it we put my spare engine in an it over fuelled massivly which was meterin unit so i ripped the whole thing apart to start again
i dont kno it was well set up mate but always ran fine an plugs were always a nice tan colour pistons look a good colour too, plan was for bigger power over winter anyway lol
so i keep gettin told mate, like i said i only assumed drawing a conclusion on wot i found but v poss i was wrong, also poss i was right tho, i took it up to an beyond that many times an for longer periods tbh lean didnt cross my mind due to the healty colour of the rest of the pistons an valves, surely if it was runnin lean it would be lean on all cylinders
Karlos G
Jan 31, 2013 10:10 PM
Iain Mac
Jun 8, 2012 09:19 PM
