CVH turbo
Old Feb 6, 2010 | 10:17 AM
xr2i-carl's Avatar
xr2i-carl
Default CVH turbo
Out of a FRST, please remind me of what to look at to confirm it's gen FRST engine ?! Oil feed etc what else oh and what side is that on?!
Can a decomp plate previously used on a 1.8zvh be used in a cvh ?
Old Feb 6, 2010 | 10:20 AM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
they will have a threed oil drain on the frount lower right hand side just above the sump and a braided oil feed (if its still running a t2) that comes over the timeing belt cover. as for the decom plate what do ya mean?? can a decomplate be used on a 1.8 zvh?? yes it can
Old Feb 6, 2010 | 10:27 AM
xr2i-carl's Avatar
xr2i-carl
Thanks for the help.
RE decomp plate, I mean one used in a zvh will fit a standard
cvh or will I need another one made
for a cvh ?!
Old Feb 6, 2010 | 10:29 AM
clarke5700's Avatar
clarke5700
for a cvh ?!
emmmm i think it will work yes
Old Feb 6, 2010 | 12:56 PM
Karlos G's Avatar
Karlos G
Balls Deep!
If you want to lower the compression on your CVH do it properly with low comp pistons, but unless your going over 300bhp there is no need as standard CR 8.5:1 is fine!
Old Feb 6, 2010 | 06:38 PM
xr2i-carl's Avatar
xr2i-carl
Only issue is the heads been skimmed loads.
JK12
33
Apr 26, 2021 12:09 PM
RSmark84
Sep 13, 2015 01:29 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
