TPS set up
hi lads wot it the best way to set up a TPS up oun a cosworth i dont think it to fare rong but it would be nice to no its right
you need to dig out the tech data, and find the voltage reading on closed throttle and wide open throttle, then pin it out with a mulitmeter and adjust to get the correct figures. then check the sweep is clean from one to the other.
unless you have iaw software, where it will show you throttle angle
