saffcoz 4x4 box broke, advice needed please
bloody cozzies
bastad things bust again
i was drivin home the other day and the gearstick on the car went a bit funny and then bust , heres what happened
it felt as if the spring theat returns the gear stick to neutral had gone and the stick jut stayed where you put it when the car was in neutral instead of springing back like normal , i kept on driving and within a 1/4 mile or so i found it hard to locate a gear with the stick, then the stick just went completely floppy and felt like it wasn't connected to the box, the only restriction stopping the stick moving side to side or top and bottom is the plastic trim around the gaiter, its like stirring a bowl of porridge, the stick doesnt move up and down and i took the gaiter off and theres nothing broke or snapped so it must be summit that connects to the bottom ofthe stick inside of the box???
does anyone know how these are connected or have any idea what it could be please, any exploded diagrams of the connection etc and can it be fixed without removing the box???
cheers
cheers
4x4`s have a small linkage on top of the box with a couple if rose type joints,chances are a pin has come out of one of the joints(they are a "c" type clip with a pin on)...............should be a piece of piss to fix mate.....
cheers chaps, glad ya liked ya message paul
, i was compleetely fookijn hammered and didnt get in till about 5, it was another agm session except i made it throught the night this time and didnt puke or pass out coz i'm a fookin bloke, i was in feurtaventura in the bars having chasers and shit, that night i sent 67 texts to people on my phone
all from spain, so i'm lookin forward to that bill coming in
.....not!!!
so this box sounds like its either a nightmare or a doddle, anyone else got any answers
.....not!!!so this box sounds like its either a nightmare or a doddle, anyone else got any answers
Roll pin has broken
It's inside the box
So, yes it's a doddle (for someone like me
) to fix, BUT, the gearbox has to come out, AND, the gearbox has to come to bits.
It's inside the box
You might be lucky mate.......its happened to me twice and both times it was the linkage pin........sorted in under an hour....
But if it`s worst case Bernies the best man in the u.k.....
big_Rad
Sep 15, 2017 09:36 AM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
