Will a 2wd saff t3 fit my series one RST ??
Old Jan 6, 2005 | 03:46 PM
nickRS's Avatar
nickRS
Default Will a 2wd saff t3 fit my series one RST ??
I know i've got to get the water feed and drain sorted, but i don't have a s2 to compare !! anyone know what parts i need ?? Are the two turbo's the same with regards to the manifold flanges ?? Please help me if anyone can.
Old Jan 6, 2005 | 03:47 PM
Ginge !'s Avatar
Ginge !
just finding my feet
ya gonna need a cossie down pips and flange too
pm spadge or paul at north yorks rs spares fopr very cheep prices
Old Jan 6, 2005 | 03:48 PM
B19-TRB's Avatar
B19-TRB
Nope it wont fit!
the flange that goes onto the down -pipe is different!
your s1/s2 has a 2 bolt flange where as the cossie turbo has a 3 bolt flange!
Old Jan 6, 2005 | 03:49 PM
CabrioTurbo's Avatar
CabrioTurbo
dont worry about the water feed... no need to use it.
you will as ginge saysneed to fabricate/fashion somesort of down pipe as the 3 stud cossie one is much different compared with that of the RST.
(unless you use an RST exhousing!)
Old Jan 6, 2005 | 03:50 PM
keithG666's Avatar
keithG666
any advantages to using the saph turbo over an S1 turbo?
Old Jan 6, 2005 | 03:55 PM
nickRS's Avatar
nickRS
Thanks peeps, i won't be buying that off my mate then !! It was cheap and recently refurbed - sounded like a good idea untill now. !!
Old Jan 6, 2005 | 03:58 PM
Ginge !'s Avatar
Ginge !
the zorst housing on a saphy turbo is .48 not .36, the 4x4 tuirbos have a tiny weeny bit larger compressor housing too
oh and they flow better due to the design
Old Jan 6, 2005 | 04:00 PM
Ginge !'s Avatar
Ginge !
depends how cheep tbh, a down pipe is gonna st ya back a MAX of 40 quid, the fabrication can be done at a zorst place and the advantage is hybrid cossie t3's are 10 a penny compared to a stage 3 erst hybrid, also ya can fit a t34 to is aswell for cheepness after too as they need the fabricated down pipe
Old Jan 6, 2005 | 04:02 PM
CabrioTurbo
i would be very interested in Buying the turbo if it is much cheapness!!!!!!
dannyblackpool's Avatar
dannyblackpool
Boost Builder
swap the ex manifolds over and it will . The core can run without water but ppl have differing opinions on that. The compressor side of a 2wd will fit perfect as same just need to swap your ex manifold for the cos one (6 bolts with clamp strips) job done
Old Jan 6, 2005 | 04:03 PM
Ginge !'s Avatar
Ginge !
vulture
Old Jan 6, 2005 | 04:05 PM
CabrioTurbo
my Stage 3 turbo in the cab is mullered!
its like smokey and the bandit at the moment!
i know the exhaust housing is good on mine too so for ease i would prob just swap them over! (as long as they will fit! )
Billy_RS
16
Oct 11, 2025 09:41 PM
Chas
Sep 21, 2015 08:57 PM
mrmann
Aug 20, 2015 11:24 PM
RsS2daz
Aug 14, 2015 05:26 AM
dlwarrior
Aug 5, 2015 10:19 AM
