Wiringloom RST vs. Bonus
Ive got a question, i`m gonna turbo my bonus, and want to know if i`ve got the swap the intire wiring loom, or can i just swap the part in the engine bay (you can split it with the connectors at the fusebox ?)
Hope someone can help
Unless you use a decent EFi setup then you would want the loom you already have, which if you remove correctly someone on another forum will buy it as these looms are great for this reason.
