Saff leather door card repair?
The 60ft Launch King
Hi All - My two front door cards have started to sag and look damn right aweful!
At the top where it meets the window it's slipped away in the middle. Also where the door pocket is you can see the actual card and holes where the leather slips in....
Now....
Is there anyway of repairing them? Or better still has someone done it? Or would it be better to just get another decent pair and chuck the sagged ones out?
Now....
Fix em mate.
Get a hairdryer on warm temp, heat up the plastic and it becomes stretchy, then spray contact adhesive behind and stick down, quite easy to do, no need to buy another
Well The Bird gets them done pro(or used to when i had my saff) and it looked the bollocks. Factory fresh.
You half scottish that you want to use a hairdryer and some cheap glue?
Excellent tip. Another little job to add to the list...
But seriously, been wondering about this one for a bit, seeing yellow on the doors looks a twat and really lets down the look, so Thanks.
did mine with a heat gun and contact addehisive spay worked a treat for
12 months but just need tweaking again on 2 of them, when heating them
up dont go mad as the hotter they get and the more you stretch them
they loose there colour (fade black) as mine did a little
will be easier if you have some help to hand
155lee
Sep 6, 2016 11:10 AM
Adam Graham
Sep 6, 2015 06:04 AM
Simples
