Rs turbo LSD details needed, drawings, dimensions.......
Does any1 know where I can get the above?
I wanna know if I can make 1 fit a different gearbox.
Or does any1 have a broken 1 I can borrow/buy for a trial?
Might be best to buy a cheap gearbox off ebay and strip it, i shouldn't think any one will have the specifics you need unless they have a measure up..... can be any box doesn't need an lsd.
What box are you thinking about fitting it to.
Rob,
Rob,
ok, i wasnt sure if there was a site that sells them that might have the drawings.
would any escort/fiesta box have the same diff in them? then obviously if it will fit i can buy a lsd later.
its to go in my renault un1 gearbox. i dont see how it will work but a couple of people have said it might with a bit of machining.
has any1 got any pics of them?
cheers
cheers
Couple of pics towards the bottom of my rebuild thread from a couple of years ago.
https://passionford.com/forum/restor...e-24-08-a.html
I have just had a good clearout at my mums where i used to store all my car stuff. Along with several broken boxes i threw an Escort LSD down the tip!
rog
Sep 4, 2015 12:10 PM
kosienutter
31
Aug 22, 2015 09:55 AM
