focus help
Old Feb 3, 2010 | 08:01 PM
woolford's Avatar
woolford
Default focus help
What is the gapping for standard spark plugs for a 1.8 and 2.0??
Also i know there isnt much point but can i put 2.0l blacktop cams straight into a 1.8 or would i need shims shimming or any other work?? as one of my cams is broke and i have 2sets of 2.0 spare
Thanks
Old Feb 4, 2010 | 08:52 AM
mercgrey's Avatar
mercgrey
with the silver top 1.8 you can put the 2l cams in for a 15bhp increase no problems but im unsure if its the same prinsiple on the black top
Old Feb 4, 2010 | 06:14 PM
woolford's Avatar
woolford
up
Old Feb 5, 2010 | 04:41 PM
woolford's Avatar
woolford
help
Old Feb 6, 2010 | 09:26 PM
woolford's Avatar
woolford
uttt
Old Feb 8, 2010 | 09:37 AM
phil_focus's Avatar
phil_focus
i'm pretty sure the black top 1.8 and 2l cams are identical and can be swapped. the best way to find out though i think would be to ring ford and check to see if the part numbers are the same.
Old Feb 8, 2010 | 05:06 PM
woolford's Avatar
woolford
ford have a really shit after sales and would rather just wait till some one can help on here thanks phil..
Plugs are sorted
Just need cams info
Old Feb 17, 2010 | 06:39 PM
hineho87's Avatar
hineho87
i think when i rang ford parts department they said the 1.8 and 2.0 cams were the same.however, i have fitted 2.0 kent cams in my 1.8 and even thought they are the same, i have no found out the power band will be slightly different as smaller capacity engine (im still happy though!!). Not sure if this will be same for std cams.Best bet is to ring ford parts department and check OR buy my 1.8 cams that i removed from my car. Only done about 48k miles and in good nickLet me noMatt
Old Feb 18, 2010 | 01:37 PM
phil_focus's Avatar
phil_focus
just check part numbers on the cams to be sure.
any ford dealer will be able to look up the part numbers in a couple of min
wowk
Mar 30, 2021 07:49 PM
tankybaby66
Feb 6, 2016 02:24 PM
Sp3no
Sep 27, 2015 07:23 PM
Tank Mike
Sep 26, 2015 08:07 AM
