S2 Rear Disk Conversion Problem
Old Feb 2, 2010 | 07:42 PM
martin24uk's Avatar
martin24uk
Default S2 Rear Disk Conversion Problem
Looking for a bit of advice
i bought a non running s2 erst and it has cosworth disks
all round, and the guy i bought it off said the brakes were pish
until they heat up.
now i was under it tonight and noticed it still has the rear brake
bias.
are you suppose to remove this when fitting rear disks???
any help or advice would be great
thanks Martin
Old Feb 3, 2010 | 06:49 PM
I would leave the bias there, defo needs one.
Not working from cold is more than likely just down to the pads/material.
siscossie
Aug 27, 2015 09:27 PM
Dr. Ickxs
Aug 15, 2015 11:34 AM
RsS2daz
Aug 14, 2015 05:26 AM
track.focus'd
Aug 12, 2015 05:53 PM
