A Quick Question for any of the P/F House Alarm Engineers
Old Feb 2, 2010 | 06:33 PM
tosh's Avatar
tosh
Default A Quick Question for any of the P/F House Alarm Engineers
I have just fitted a new upvc front door and now need to refit the magnetic reed switch to it, I spoke to a spotty kid in maplins "probably the manager" and he said that you can only place them side by side with the screw heads facing you which is how it was on the old flush timber door, is this true or can you turn the magnet sideways on the door section as shown in the diagram, the red dotted lines are screws by the way.
I will be packing out the reed switch to the position of the magnet.
Any help appreciated cheers
Old Feb 2, 2010 | 06:58 PM
danneth's Avatar
danneth
TORQUE!
depends on the type of door contacts, quite a few wont work like that
Old Feb 2, 2010 | 07:03 PM
tosh's Avatar
tosh
I will get a photo up of which one that was on it, I thought they were all the same??
Old Feb 2, 2010 | 07:14 PM
rstdave's Avatar
rstdave
If you think it will work why not just try it and see if it makes contact? Don't know what alarm you have but the Gardtec ones i fit on occasion you can just put it in test moe to see if things like mag catches are working effectively. As said though, some are 'polarised' if you like, where the part with the wiring in needs to be facing the magnet in a certain way.
Old Feb 2, 2010 | 07:19 PM
tosh's Avatar
tosh
Is this any help? or can you get one that is designed for stepped door and frames, it is 65mm long x 15mm wide
Old Feb 2, 2010 | 07:21 PM
St3V3_C's Avatar
St3V3_C
As above, hold it up and try it. If you listen really carefully, you can usually hear the click as it operates. Proper quiet though...
Old Feb 2, 2010 | 07:23 PM
St3V3_C's Avatar
St3V3_C
If you need to space it off by quite a lot, I have used the switch one from another pair underneath as a spacer
Old Feb 2, 2010 | 07:27 PM
dojj's Avatar
dojj
Resident Wrestling Legend
just space them out to be level like they were before
Old Feb 2, 2010 | 07:32 PM
Ben M's Avatar
Ben M
i would say that would work with the one pictured above, very good reliable ones them
Old Feb 2, 2010 | 07:33 PM
Ben M's Avatar
Ben M
try it first though with some blue tac before you drill the nice new door lol
Old Feb 2, 2010 | 07:36 PM
tosh's Avatar
tosh
Cheers for the replies Gents, I just tried what St3V3 C said and it does clink on all 4 sides of the magnet also by the looks of it I probably won't need to space the reed switch section off the frame because it clinks when the magnet is about 10mm away,
Happy Days! thanks again
Old Feb 2, 2010 | 07:51 PM
St3V3_C's Avatar
St3V3_C
Cool.
bigryrs
Mar 28, 2016 09:11 PM
Anutternutter
24
Aug 31, 2015 01:24 PM
Gadget
Ford Escort RS Cosworth
Aug 13, 2015 06:43 AM
Ben26
Aug 11, 2015 04:19 PM
liam-rst
Aug 10, 2015 08:46 AM
