1.8 zetec wanta run on carbs
buy twin 45 carbs for a zetec, throttle linkage,air filter, an inlet manifold,a fuel pump and regulator and ignition system to run it.fit all this to engine and voila....
for ecu and loom try here
http://www.specialist-components.co....lated_products
for carbs you can purchase through ebay.get the zetec specific ones
as above take the engine wiring off a escort or fiesta 1.3 hcs engine
it connects to the cps,edis module, coil pack, etc and just plugs into the car loom with just 3 wires
very easy to do
very easy to do
