Temperature sensor
Old Feb 2, 2010 | 02:58 PM
grayboots's Avatar
grayboots
Unhappy Temperature sensor
Hi All,
My 1.8 zetec focus mk 1 has fault with the temperature display. I have bought a new sensor. Does anyone know where it lives. I was expecting to find it in the cylinder head or the thermostat housing ? any ideas
g
Old Feb 2, 2010 | 03:17 PM
FrOd's Avatar
FrOd
Under the bonnet slam panel.
Old Feb 6, 2010 | 10:06 PM
pdfbt40's Avatar
pdfbt40
FrOd is referring to the external temperature sensor for a trip computer.
The engine temperature sensor is at the back of the engine under the inlet manifold above cylinder 1. Its a cylinder head temperature (CHT) so can be changed without any coolant loss.
However, if it is faulty, it would probably have effected the engine running as much as the indicator. The dials in a Focus are not independent devices. They are driven by digital highway from the PCM. In the case of the temperature it even adjusts the CHT to give a coolant temperature for EOBD.
Martin
Old Feb 8, 2010 | 07:20 AM
grayboots's Avatar
grayboots
Thanks martin. I see it now, and the broken wire thats shorting to the alternator pulley.
all sorted.
Thanks again
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
