Best Way To Stage 4 A Saff
Old Jan 6, 2005 | 11:57 AM
Mr Brannen's Avatar
Mr Brannen
Default Best Way To Stage 4 A Saff
Looking to up the power on my saff, need some advice, my car has a T3 Hybrid, Dark greens,200Block, Wanna go for the new T38 but wanna know what you's think....
Old Jan 6, 2005 | 12:01 PM
benporter's Avatar
benporter
I think ur car will still be slower than mine
Old Jan 6, 2005 | 12:21 PM
CraigN's Avatar
CraigN
if u want over 380bhp yoru best removing the head and getting it ported polished flowed
depending on what map you want and what ecu you have there are many choices
Old Jan 6, 2005 | 12:23 PM
benporter's Avatar
benporter
When would youneed to change pistons?
Old Jan 6, 2005 | 01:43 PM
Ginge !'s Avatar
Ginge !
just finding my feet
speak to ya tuner and goe by what he recomends tbh mate, at that spec its a different ball game
Old Jan 6, 2005 | 01:54 PM
Jim Green's Avatar
Jim Green
Sounds like your doing what I'm in the middle of.
Karl is doing my engine for me, (Stg 4 "420bhp"). I was going to do it all on a standard comp bottom end, but for the sake of spend abit more, i've decided to go semi low comp in an effort to keep it reliable and as a better stg 4 conversion.
Basically Fully Modified Head by Karl including different valve springs, + his own cams, T38 (Universal Turbo's Version), Greys, EEC IV Inlet Manifold and flowed inlet tracts, Obviously Fully rebuilt Bottom End.
You could probably do it all using a very good standard comp bottom end, which I intially wanted to try, but after spending so much on the head, turbo, inlets etc, I decided to go the whole hog and have the bottom end done as well.
I would say I'll let you know how it goes, but I have to go over to the USA for about three - four months as I work over there, but I'll let everyone know when it's finished.
There are two versions of the T38 going about at the moment, One is i believe Turbo Technics which is a full one off. (And appears to have surge problem if used on anything but a fully flowed head) and the other is Universal Turbo's version, which for me, is the better of the two for what I want.......... High Torqe, Low lag.
But it depends what your after as to which is more suitable.
Old Jan 6, 2005 | 01:56 PM
benporter's Avatar
benporter
Thanx
Hes going with turbo Technics,he did say to me they said he would need to port the head
gcfcos
59
Oct 6, 2015 05:04 PM
Mc5506
Oct 5, 2015 09:57 PM
A.t.p
Sep 29, 2015 05:04 PM
cossie330
Sep 27, 2015 04:13 PM
ajamesc
Sep 27, 2015 02:25 PM
