Comments on my handling spec ideas
Old Feb 1, 2010 | 09:08 PM
MunkeyboyRS's Avatar
MunkeyboyRS
Bananas!
Default Comments on my handling spec ideas
Hi all
Well the plan into repairing, upgrading and restoring my car after my bump.
Been doing lots of thinking on parts. Now I'm happy with just shy of 200bhp, the full round number would be nice but nit important, so the engine is going to be left alone apart form a good service, but that's another day.
So I wanna go to town on the handling, so here my idea and if anyone has improvements or different ideas do let me know.
Using my exciting Koni adjustable shocks,with new springs, I'v got a the mo, -40mm cut (previous owner), I really like the look, but I know its not good!
So thinking either non cut -40mm or -35mm. Any idea on whos springs?
Adjustable TCAs, either a new set from Compbrake, or the Old skool style ones I've got, kinda home jobs ones.
Rose Jointed Steering arms ends.
Adjustable top mounts
Anti roll bar, I've been thinking about using a RS16i unit, but the means different gearbox and not mage keen on doing that.
Second option some adjustable ARB for a mk4 the is very rare and cost lots, but thats all i know about it.
Third option is using the thinker ARB for a mk4 I have in my garage.
Any other options for ARB?
Full new polybush kit.
Front Strut Brace
Rear Strut Brace
Not it the rear end I have no real idea about, Some one told me about adjustable trailing arms, but I cant find anything online. Also seen on the Compbrake site a link call "ford mk4 adjustable rear wishbones" but the link don't work, so any more info on this would be good to.
Wheels will be the standard alloys with toyo tr-1s
Cheers for any help and info.
Old Feb 1, 2010 | 10:56 PM
boothy's Avatar
boothy
Try mef.com or something like that they got some sexy stuff
Old Feb 1, 2010 | 11:08 PM
botters's Avatar
botters
competant bodger
mef dont do the rs turbo stuff anymore yet they do still advertise them on the website!!!
Old Feb 1, 2010 | 11:09 PM
tasos77's Avatar
tasos77
rs turbo from Greece...
http://compbrake.co.uk/shop/product_...roducts_id=267
Old Feb 2, 2010 | 12:30 AM
Micky's Avatar
Micky
Ring Tony in my sig. Micky
Old Feb 2, 2010 | 08:37 AM
project rs's Avatar
project rs
you really need to get rid of arb and put some proper coilover on it and not the gaz's some billies would be nice like the ones mef did and all your other ideas for the front i currently run with a propper motorsport rack and you just point it where you want to go and it drags itself there and rides lovely on bumpy roads no being pulled from side to side, the rear to go adjustable really you need coilovers and rear discs to push wheels out and then bin rear arms for adjustables but you will need to go to a specialist to get all that set up but will handle a treat and with 200bhp make a great lively car
Old Feb 2, 2010 | 11:44 AM
MunkeyboyRS
Bananas!
Sorry bud, might be a combination of my shit reading skill but that doesn't make sence to me 100%. I've got saff 2wd brakes all round. I've been thinking bout coilover but I think they are a lil extreme for just road use, I'm not making track car and I think I'm right in thinking I need the back end seam welding up?
Old Feb 2, 2010 | 11:50 AM
MunkeyboyRS
Bananas!
Cheers Micky, I had already thought bout ring him after seeing one of you earlier post.
What set up do you run?
Old Feb 2, 2010 | 12:10 PM
rs combi's Avatar
rs combi
this is the setup i will be running on my mk 3 not finnished yet tho
already got gaz coilovers on and should be getting some topmounts off compbrake
will be using the antiroll bar as well but havent made the clamps yet
possibly running a rear antiroll bar as well as above need to make some clamps up for this
Old Feb 2, 2010 | 03:33 PM
project rs's Avatar
project rs
thar rs combi is one nice set up but the standard mk4 can't take it due to cradle for gearbox but is the way forward, you could do away with the arb and use compression struts as you've got coilovers and then be fully independent p.s adjustable top mounts or just solid top mounts
Old Feb 2, 2010 | 04:35 PM
rs combi's Avatar
rs combi
its all going in my mk3
still going to run the roll bar just got to finnish drawing the clamps up and then make them
i was going to run the solid top mounts but if i can find any decent adjustable ones then i prob will use them.
thinking about adjustable topmounts on the rear aswell
Old Feb 2, 2010 | 04:42 PM
xrmalin's Avatar
xrmalin
Ive been looking at upgradeing afew bits on my car since ive put the coilovers on i seen some top mounts and adjustable bottom arms for the front on the compbrake website but i was just wondering what there like to live with day to day
cheers mark.
Old Feb 2, 2010 | 06:00 PM
MunkeyboyRS
Bananas!
This is a front set up I've looking and and really like the idea, apart form having to change the gbox, but if it is really that well recommended the I may have to.
Sorry but I dont know what the parts are in the second pic or what they are for?
cheers
Old Feb 2, 2010 | 06:15 PM
project rs's Avatar
project rs
second pic is to replace rear arms as he's on coilovers so no need for spring platform and XRMALIN i run solid top mounts and adj tca's on my daily driver with coilovers and it's never felt better best setup i've had and not harsh like everyone with the gaz's seems to have but got them second hand so don't know poundage of springs
Old Feb 3, 2010 | 09:22 PM
MunkeyboyRS
Bananas!
Still thinking bout my ideas.
Dose the back end of the car need seam welding to have coilovers?
Old Feb 3, 2010 | 09:33 PM
project rs's Avatar
project rs
track/rally no but road depending on if you plan on carrying more than 1 passenger
Old Feb 3, 2010 | 09:44 PM
MunkeyboyRS
Bananas!
Well it will be a fast road and show car, and I dont let people sit in the car of the car, so its really only a 2 seater, so would it need it?
My new idea is -40mm spring on my koni's, rear strut brace, front strut brace, adjst TCAs, Tie/track rod ends, full new poly bush kit. Then once I got the body repaired form the bump and let my banck accout recover, I shall come back to the Coilover and everything adjst plans.
But i was thinking that when we are welding and cut the rot, if i shoulf seam weld the car up.
Old Feb 4, 2010 | 12:28 AM
Micky's Avatar
Micky
If the car is only a road/show car like you say,then I wouldnt bother spending cash on making it adjustable.Total waste of money.Koni's,springs (not -40mm,but -25mm)fully polybushed will do the trick nicely.Use the money saved for beer!!! Micky
Old Feb 4, 2010 | 12:56 AM
jonny s2's Avatar
jonny s2
tbh bud micky is bang on there, maybe put adjustable front tca's and job done with some konis,
mine will be running adjustable mef front tca's a ultra rare tt arb, gaz coillies all round, and mef rear setup, and its been seam welded for extra strength
Old Feb 4, 2010 | 09:15 AM
MunkeyboyRS
Bananas!
Only thing is I'm one of the few 24year old lads out there that is nearly tea total, get my kicks from smoking weed and that's pretty much free for me.
The car is going fast road and the occassional track days. But want it the best I can to give my mates 306gti6 a run for it's money in the bends.
jessie_rs
62
Aug 6, 2019 09:27 PM
Kam B
Sep 24, 2015 10:40 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
Rizlablue
Sep 6, 2015 09:58 AM
hopper350
Sep 4, 2015 12:53 AM
