P jet restictor in boost pipes ?
do ford use this in the pipe work to help with boost, im just trying to understand how the pill jet restictor works ? they fit into the boost pressure inlet line to the actuator here,s a quote from MLR intresting read i thought
How Do We Get Good Control At Both Low And High Boost Pressures?
This is done by using restrictors in the pipework to allow a small amount of air bleed to make a big difference in the pressure that the actuator is seeing.
If you fit a restriction into the boost pressure inlet line to the actuator then you cause a pressure drop across the restriction. This means that the pressure after the restriction is lower than it was before (remember the water tap scenario).
andy
andy
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
