my car is going MSD tomorrow
Jan 31, 2010 | 07:39 PM
sideways most if the time
My car is in for a full set up and a stage 3 to come home with
Can not wait...
Jan 31, 2010 | 07:43 PM
Jan 31, 2010 | 08:13 PM
That'll be a nice journey home m8.
Jan 31, 2010 | 09:32 PM
like ksa said,the journey home will be mint,did it myself just this week!!
Jan 31, 2010 | 09:40 PM
best of luck mate ,i bet you will have a big smile on your face on the drive home
cheers james
Jan 31, 2010 | 09:41 PM
Mind out on Faraday way, all sorts of dickheads park on the corners and you might have a lorry headed your way on a blind corner.
Go the other way round, down ashfield road!
Feb 1, 2010 | 05:59 PM
Well what can i say but WOW
jame's did a fantastic job
Only need to fit a new clutch as it can slip at time's,next week shopping bill
Feb 1, 2010 | 06:08 PM
did you get away with a basic setup damian?
cheers james
Feb 1, 2010 | 06:51 PM
what did it make and what clutch u running
Feb 1, 2010 | 06:59 PM
Quote:
Originally Posted by
Moonstone Mo
When's the next power upgrade then mo ??
Feb 1, 2010 | 07:06 PM
james kiely
cheers james
Yeah mate as it had a set up 9-10 month back,so all the things were fixed...Also had the fuel pump wiring loom redone..
Feb 1, 2010 | 08:20 PM
KSA-Cossie
Had my brakes sorted as i cooked them on the way home
then i think im fitting a new fooooking headgasket
pulled up last nite after a drive,firing on 3 cylinders,had a proper ganda today no water loss,no oil in water no power loss..getting the fooker pressure tested...so yeah thats my 'upgrade' at the moment KSA
yawiejon
15
Aug 9, 2015 06:36 PM
sridgett
18
Aug 1, 2015 08:49 PM
TommysKeeper
Shows & Track Days
Aug 1, 2015 12:59 PM
fuzzy
Jul 31, 2015 11:40 PM
tejy
Jul 31, 2015 05:09 AM
