hall effect sensor
Old Jan 31, 2010 | 07:14 PM
THE RADMAN's Avatar
THE RADMAN
Default hall effect sensor
on the small t es cos what are you supposed to see through the small window in the sensor and how exactly does it work? and line up etc? these things seem to be a bit of a mystery lol
Old Jan 31, 2010 | 07:55 PM
The Youth.'s Avatar
The Youth.
the line on the window lines up with the black line underneath, the bit you need to line up is the point where the line gets thinner.
edit found the pic
steve
Old Jan 31, 2010 | 09:31 PM
THE RADMAN's Avatar
THE RADMAN
there is a raised lip inside which goes about halfway round so presume you line it up with the tail end of this? where did you get the pic steve as i cant find any info on these
Old Feb 1, 2010 | 06:48 AM
THE RADMAN's Avatar
THE RADMAN
up for the monday crew
Old Feb 1, 2010 | 03:53 PM
THE RADMAN's Avatar
THE RADMAN
up someone must know about these things?
Old Feb 1, 2010 | 05:46 PM
The Youth.'s Avatar
The Youth.
line it up as the pic explains the line on the window with the end of the solid big line just where the thin line starts.
use a torch and it's easy
steve
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
