AFR readings
Old Jan 31, 2010 | 07:04 PM
COLEYST200's Avatar
COLEYST200
Default AFR readings
Come on then lads wot readings do you lot think a stack AFR gauge should be showing
1. tick over ..............cold..?
2. tick over ..............hot...?
3. driving 3,000rpm............?
4. no boost......................?
Old Jan 31, 2010 | 07:24 PM
HockeyNomad's Avatar
HockeyNomad
I can tsay exactly what AFR's you will see, but on cold start it will be quite rich, but depends on map tbh,
warm tick over should be around lambda 1 or 14.5 AFR
driving at 3000 rpm, i assume you mean part throttle cruising on a motor way etc, then i would expect around 14.5
no boost? i assume you are referring to wide open throttle acceleration before the tubo boost threshold, this again should be around 14 AFR maybe a little richer, but as boost builds it should get richer in line with boost increase, down to as low as 11:1AFR but around 12.5 - 11 AFR i would expect to see on boost,
all mapping dependant really but hope this is enough of a guide for you.
Old Jan 31, 2010 | 07:26 PM
105epwr's Avatar
105epwr
what he said!
Old Jan 31, 2010 | 07:59 PM
COLEYST200's Avatar
COLEYST200
Thanks for that we are not fare out with wot you are saying with the way the car is set up now . but to start with it was way out . we got the car started and got it warm and we had 11/11.2 on tick over so we set the ECU up to 14 and wot a different car to drive
Thanks for the in put lads
Old Jan 31, 2010 | 08:16 PM
rich123's Avatar
rich123
same as above y whats urs reading?
Old Jan 31, 2010 | 08:57 PM
COLEYST200's Avatar
COLEYST200
well iv just started the car from cold and these photo,s are wot i have at the mo
Then i left it to warm up for a bit 80*c
Old Jan 31, 2010 | 10:44 PM
mechanic28's Avatar
mechanic28
whats it doing on full boost/load?
Old Jan 31, 2010 | 10:52 PM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
Your car would have left me with sane afr readings so if they have changed then so has something else!
Old Jan 31, 2010 | 11:12 PM
COLEYST200's Avatar
COLEYST200
As you say mart it would of been right when you put the chip and injectors ansd put the sniffer up the pipe . but over xmass we put a swedish plenum on it and it had a very bad back fire when on boost . so we put REX,s AFR up the pipe and re set it up but to be onist its been running like a pig and when its cold it back fires and so i new it was all over the shop . MART im going to send you a PM
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Iain Mac
Sep 30, 2015 09:39 PM
20/20 vision
Sep 29, 2015 11:27 AM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
