Idling problems zetec 1.25
Old Jan 30, 2010 | 03:35 PM
Cuffer's Avatar
Cuffer
Default Idling problems zetec 1.25
Hi I'm a new member, Just drove my mothers car and it has a problem which I would like to fix myself as I hate paying extortionate garage fees.
Fiesta 1.25 zetec "T" reg. 7200 miles. The engine is over running when coming to a stop. It revs up to 2000 rpm then dies back to 1000rpm after about 5-10 secs which i think is still a little high for idle.
Any advice please?
Many thanks in advance
Cuffer
Old Jan 30, 2010 | 03:45 PM
wirralphil's Avatar
wirralphil
Clean the Idle Control Valve. WD40 and an air compressor to blow it through.
Should be 2 or 3 bolts holding it on under the inlet.
Old Jan 30, 2010 | 03:54 PM
MarkyMark's Avatar
MarkyMark
either idle control valve as above or throttle position sensor, more then likey the icv though, two bolts 8mm iirc, if you do go for a replacement make sure you match it up by comparing the underside (side which bolts onto the engine ) and matching one with the same pattern up, there are two types one with circle cut outs and one with a more square cut out
shouldnt be no more then 25 quid for a scrappie
Old Jan 30, 2010 | 03:56 PM
Cuffer's Avatar
Cuffer
Many thanks Phil will look @ it tomorrow (as long as it doesn't snow again tonight)
Regards
Cuffer
Old Jan 30, 2010 | 03:59 PM
Cuffer's Avatar
Cuffer
Thanks Mark will carry out Phil's solution first and then down to the local ripoff scrappy where everything is "plus vat" lol
Regards
Cuffer
Old Jan 30, 2010 | 05:02 PM
RS SHORTIE's Avatar
RS SHORTIE
My sisters did this and all we did was disconnect batery for about 30mins then reconnect.
Might be worth a shot first
Old Jan 30, 2010 | 05:08 PM
iscv it has 2 8 mil bolts which u need to undo. Then remove the connection and give it a good clean out.
Old Jan 30, 2010 | 06:51 PM
Look at the wheel speed sensor, the rpm is artificially held high when driving to aid smooth gear changes, it sounds as though it is not getting a good enough signal from sensor that it is stopped moving.
RSmark84
Sep 13, 2015 01:29 PM
Marino
Sep 12, 2015 11:10 AM
BRAM
Sep 8, 2015 07:11 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
routemaster
Sep 7, 2015 05:27 PM
