do you think im making a mistake
Old Jan 29, 2010 | 02:08 PM
alangti's Avatar
alangti
Default do you think im making a mistake
right at the minuite on my car its lowered 40mm at the back and 35mm at the front on full koni adjustables
at the minuite ive got a set of 7.5x17" tsw evo-r alloys fitted but upon inspection at the body shop asfter replacing the 2 rear tyres they are ripping the rear arches to bits and also damaging the side walls on the tyres too.
this is how it looks at the min
now ive been offered a straight swap for a very clean graphite grey set of 16" mondeo zetec alloys like the escos 1s with 195/45/16 tyres fitted all good tyres too
my question is should i swap after ive just bought a brand new set of centre plates had all my wheels re-furbed bought toyo t1-s tyres for the front which have done 0 miles and bought falkens for the rear which also have done 0 miles bought a brand new set of black centre nuts and also a blue set new pind for the centres and the inner tsw caps plus had the ford motorsport logos added to esch wheel. im not overly fussed on the cost of mine tbh just dont know if the other wheels will look as good as mine or not also how much are 195/45/16" tyres to buy too
cheers for any help
Old Jan 29, 2010 | 02:11 PM
T28 RST's Avatar
T28 RST
Ok then
Keep the alloys you have and get the rear arches trimmed
Old Jan 29, 2010 | 02:16 PM
fiend's Avatar
fiend
As above, the TSW alloys look awesome!
Old Jan 29, 2010 | 02:19 PM
Brian ST-2's Avatar
Brian ST-2
Yeah man, keep those minter wheels, they really make the look of your car.
Get the arches trimmed or rolled to ensure clearance and you're good to go.
Old Jan 29, 2010 | 02:34 PM
alangti's Avatar
alangti
you know what i never even thought of having the arches rolled DOH!!! cheers boys
T28 RST how low is the front of your car and are those 17"s mate ??
Old Jan 29, 2010 | 02:36 PM
.Ross.'s Avatar
.Ross.
Get it sold and buy the AS escort ... You know you wanna
Old Jan 29, 2010 | 02:40 PM
T28 RST's Avatar
T28 RST
Ok then
The sig pic has been modded slightly
This is how it sat with 25mm lowered springs
This was it full of camping gear, it only rubbed on big dips on the road.
Old Jan 29, 2010 | 02:46 PM
d4 rst's Avatar
d4 rst
DADDY RST
Keep your wheels mate.
Old Jan 29, 2010 | 03:05 PM
Trim the arches job done ,mine does not rub at all,looking at your pic would say the rear needs to come up a bit anyway
Old Jan 29, 2010 | 03:22 PM
alangti's Avatar
alangti
i thought that but were would i get 2 rear springs to fit on koni shocks ??
Old Jan 29, 2010 | 03:23 PM
alangti's Avatar
alangti
ive got the cash here for the gti ross just waiting for the im selling now from you
gonna have the gti as daily and keep the rs tucked away cosy when its freshly painted like i did with my old 1 lol
Old Jan 29, 2010 | 03:31 PM
S1 Combi's Avatar
S1 Combi
The rear spring dont fit onto the shock so you can use and make of spring and i would say keep your wheels mate as they look the nuts
Old Jan 29, 2010 | 03:36 PM
jonny s2's Avatar
jonny s2
just trim ur arches
Old Jan 29, 2010 | 03:39 PM
RichieST's Avatar
RichieST
keep the wheels for sure! As twins says, get it sitting level too, does it not handle odd with the back lower than the front? Thats why FWD cars seem to sit higher at the back, to aid the handling isn't it?
Old Jan 29, 2010 | 03:42 PM
H7 CYA's Avatar
H7 CYA
keep them wheels they suit it. as above nip a bit of the arches.
Old Jan 29, 2010 | 04:18 PM
alangti's Avatar
alangti
i didnt realise i could use any spring ill now look for a pair of springs what do you reckon to the drop ?? ill get the arches done when its in the body shop too
cheers for all the help i will now keep these wheels too
the car was already lowered when i got it i wouldnt of lowered it like that i was told the front was 35mm and the rear 40 but the back looks a lot lower than 5mm difference do you think 30mm rear springs will even it out ?
Old Jan 29, 2010 | 04:32 PM
project rs's Avatar
project rs
rally design do different poundage and height springs
Old Jan 29, 2010 | 05:24 PM
alangti's Avatar
alangti
cheers ill check it out
Old Jan 29, 2010 | 05:40 PM
RichieST's Avatar
RichieST
Could you not just get a set of 4 springs and fit the lot? Might cost you Ł30 or so more but at least you will have a new matching set!
Old Jan 29, 2010 | 06:39 PM
Rick's Avatar
Rick
they actually handle better with the rear lower.
T28 and Alan - both lovely looking cars.
Old Jan 29, 2010 | 06:42 PM
JesseT's Avatar
JesseT
Do you know the rubbers on top of the rear springs? If you find an extra pair, you can fit those to the bottom as well to bring the car level. This is how mine has been now for a few years.
Old Jan 29, 2010 | 06:46 PM
botters's Avatar
botters
competant bodger
mine handles a lot better with the back higher than it ever did with it lower, with fwd you want the back end high and quite soft this keeps the back end loose and it follows the front better, also very good for lift off oversteer. having it higher also aids traction to the front for launches
Old Jan 29, 2010 | 06:51 PM
Tony Rs's Avatar
Tony Rs
Ebony black Sapph Cos
Id say keep your wheels mate and get a set of 25mm springs for the rear they are so easy to change at the back too it will take you at the most half hour to change them
Old Jan 29, 2010 | 07:44 PM
alangti's Avatar
alangti
sweet i would buy a full set of springs but i hate doing the front 1s i might roll the arches see what its like and maybe buy a new set of rear springs as it looks a bit odd
Old Jan 29, 2010 | 08:22 PM
Tony Rs's Avatar
Tony Rs
My old s2 has 35mm spax springs all round and it sat really well mate
heres a pic of her
Old Jan 29, 2010 | 08:45 PM
alangti's Avatar
alangti
yea that does look beter thats what mine is at the front think i should get some new rear springs u not got her now mate
Old Jan 30, 2010 | 12:05 AM
Tony Rs's Avatar
Tony Rs
Not anymore mate after having 5 rs turbos i decided it was time for a cossie so i sold her to a mate and hes now sold it on but i bloody miss that car had full leather etc was a nice un
Old Jan 30, 2010 | 04:59 AM
d4 rst's Avatar
d4 rst
DADDY RST
Keep your rims.
Old Jan 30, 2010 | 06:37 AM
Ginger Will's Avatar
Ginger Will
Originally Posted by d4 rst
Keep your rims.
+1
Old Jan 30, 2010 | 08:34 AM
mulla's Avatar
mulla
keep them
Old Jan 30, 2010 | 01:37 PM
rsturbo1's Avatar
rsturbo1
what colour are those wheels on the red 1 and what size tyres are they. what does trimming the arches actually involve think im gonna need myne doing just put 17s on with 215s on the front and 205s on the back with standard springs and they rub like mad.
Old Jan 30, 2010 | 01:39 PM
ZTSI's Avatar
ZTSI
keep wheels and get her sitting level!
TPM961
Jan 15, 2018 10:50 AM
SMILER258
Sep 28, 2015 09:04 AM
gcfcos
24
Sep 21, 2015 04:26 PM
