missing hard on boost?
Old Jan 5, 2005 | 05:09 PM
essexrsturbo's Avatar
essexrsturbo
Default missing hard on boost?
have been running about 20psi of boost on me motor for a while now with no problems, but they wernt the best plugs or leads i woz used so thought i be safe and buy all new stuff for the ignition system, so went out and got me self a set of cossie motorsport plugs, beru leads, 2WD cap, rotor arm, and ignition coil all new, then gapped the plugs to 24 thou. but now car misses and splutters on full boost (never did this before) so ive turned the boost down and now its fine, but want to run the same boost again, any ideas as to why it does this at high boost and not at low, could the plugs be getting blown out? any suggestions would be much appriciated!
CheeRS!
Aaron
Old Jan 5, 2005 | 05:34 PM
essexrsturbo
Old Jan 5, 2005 | 05:53 PM
TIFF's Avatar
TIFF
Chasing Radders
Sounds like a plug issue mate
Old Jan 5, 2005 | 06:29 PM
James Porter's Avatar
James Porter
May be overboosting mate
essexrsturbo
thats wot i woz thinking tiff, do you think they could be getting blown out or just not sparking properly, or gaps wrong? really would like to get this sorted as soon as.. thanks for the help.
Old Jan 5, 2005 | 06:30 PM
essexrsturbo
na its got a unlimited boost superchip.
Old Jan 5, 2005 | 06:31 PM
essexrsturbo
and it woz running exactly the same boost fine before i changed everything above.
Old Jan 5, 2005 | 06:35 PM
Šhatter Box's Avatar
Šhatter Box
hope u got the fuleing for 20psi sounds like ur spark is getting blown our on full boost that what i got on mine with the ngk plugs once. so i just put a set of 701s in and that cured the trouble
Old Jan 5, 2005 | 07:03 PM
essexrsturbo
yea fuellings sweet, ive got a set of Ford Motorsport Platinum PP8 plugs i at the mo, you rekn the gaping could be wrong?
Old Jan 5, 2005 | 07:16 PM
DazC's Avatar
DazC
missing hardon boost?
Viagra?
Old Jan 5, 2005 | 07:29 PM
essexrsturbo
Old Jan 5, 2005 | 07:33 PM
Wazzzer's Avatar
Wazzzer
boost blowing the spark out, tried slightly bigger gaps?
Old Jan 5, 2005 | 07:42 PM
essexrsturbo
if the boosts being blown out, do the gaps need to be larger or smaller? as i thought the smaller the gap, the less chance of it happening.
cheeRS
Old Jan 5, 2005 | 08:29 PM
essexrsturbo
Old Jan 5, 2005 | 09:05 PM
Eagle's Avatar
Eagle
Super Moderator
smaller i would of thought
Old Jan 5, 2005 | 09:21 PM
CosKev3's Avatar
CosKev3
Defo smaller m8
Old Jan 5, 2005 | 09:24 PM
essexrsturbo
cheeRS lads
Old Jan 6, 2005 | 12:06 PM
essexrsturbo
Old Jan 6, 2005 | 12:36 PM
DaveEscos's Avatar
DaveEscos
Originally Posted by essexrsturbo's signature
cossie management OR anything ford?
ring jano on: 07050133596 OR
check the website out at:
www.oddkiddcreations.co.uk
surley thats the way??
Old Jan 6, 2005 | 12:46 PM
essexrsturbo
i annoy him enough as it is davE!
thought id see wot you lot think
timsrs
Nov 13, 2018 11:48 AM
gambo08
Feb 4, 2016 10:49 PM
Fil
Sep 30, 2015 12:08 PM
SMILER258
Sep 28, 2015 09:04 AM
Russ Payne
Sep 25, 2015 08:29 PM
