MFI Big Valve Stg3+ Cyl-Head
MFI stg3+ ported and polished big valve head, comes with kent 'race' solid lifter camshaft with RS1600i adjustable solid tappets & Bronze valve guides...it had done around 1500-2K miles before I stripped the car. on a ZVH it was making 265@wheels (close to 300bhp@fly)
£400ono
st3 head from burton is £591 and the camshaft is £162, and im sure the tappets (which are like new) were around 15 quid each from ford when they were available!
Pics available on request.
Cheers.
£400ono
Cheers.
Can you advise me what size the valves are and wether your running sodium filled or stainless steel valves and if the seats are hardened and 3degree angled?
and who done the porting and flowing?
thanks
thanks
Sure the valves are Stainless, will need to check the sizes of them, possibly 42 or 45mm? also not sure on 3 degree/angled...The work was carried out by 'blane precision engineering' up here in Scotland.
Will get the info you need tomo.
Would preffer to sell as a whole atm mate, the solid lifters would be no use for your camshaft so i'd need to keep them also and tbh Prob wouldnt sell the head without cam/lifters for less than £350. I imagine shipping would be around £30 due to weight?
